URGENT!! Volvo 3.0 valve oil seal - Don, hope you're around :P
ss9940_2
Hi guys!
I have a very BIG problem. My friend has a 3.0 1996 volvo in his Wellcraft excel 21, and last year his head gasket began to leak oil on one side, so he decided to change it this year. He gave the boat to a car mechanic, and supplied a new head gasket. The guy tore the engine apart, and while he worked on a his head, he suggested to change the valve oil seals cause they looked bad to him. Now, the big trouble is that there is no part number / i can't see the part on dougrussell anywhere. It is the rubber seal that goes under the valve spring (part 20), don't know how to name it:
3.0 head diagram
Well, i can find that part on the other engines (like 4.3, part no.6):
4.3 head diagram
Why isn't there any part specification for a 3.0? I'm confused. Hope you can help me out cause we want to go boating next weekend and i would really like to help him out.
Thanx in advance,
Alex
Don S
Re: URGENT!! Volvo 3.0 valve oil seal - Don, hope you're around :p
Item 16 (in your 3.0L link) is the only seals the 3.0L gets.
ss9940_2
You're da man, DON! I ordered those seals (#16) from dougrussell, but the part the mechanic removed is bigger and made of rubber. As i said, he has removed it from under the valve spring. Here is a picture:
Did he screw up badly? Can he put this rubber part back? Or can we forget about the head?
Sorry about the quality of the picture, but i'm not at home currently and trying to save the problem.
YOU'RE A LIFE SAVER, DON. If you ever come to this part of the World, lemme know (Slovenia, east of Italy - Adriatic sea). You're in for a treat.
Thanx again,
Alex
Don S
He can put them back on if he want, or leave them off completely. They are not needed.
ss9940_2
Awesome! Thank you very much! Hehehe how is the retirement going? Guess you're relaxing and giving consultation in one or two sentences only :p But what would the forum be without you, eh?
Thanx again,
Alex
ss9940_2
Any 1 knows why they put these rubbers in anyway?
Thanx
Alex
There are Different types of Valve Seals,........
The 1 in your picture is known as an Umbrella Seal.......
The 1s in the link above are O-ring seals........
You can use Either 1, but Not both........
