US Engine. . Company info needed
Re: US Engine. . Company info needed
Ayuh,... I've heard nothing Bad about 'em,... Most guys here seem to Love Rapido Marine motors...
HT32BSX115
Howdy,
A couple of "Summers" ago, I installed a "USENGINES" 3.0L reman engine in a friends boat.
Other than being a little light on the paint in some places, I was happy with the engine. So Far, my friend is happy with the "new" engine. His "core" engine was a freeze damaged/cracked block and US Engines still gave him half "core" return value.
If I needed a replacement engine, I would buy from them for my boat. I would save the shipping though since I only live about 25 min away.
If you're on the other side of the country, you might be better off to find someone local so you can save on shipping and look them in the eye if there's a problem!
Cheers,
Rick
I live in VA so I would be shipping my old engine to them and then they are going to dress the new rebuilt with all the parts from my old engine and ship it back to me so it is ready to drop in. The shipping is only 250 each way so 500 total. The nice thing about them is they give you a 7 year 500 hour warranty!!!
Fishermark
Surely you can find a local reputable machine shop who could do the same thing for less money? $500 shipping seems pretty steep to me.
What size engine are you shipping to them?
HT32BSX115
You might be better off going to a local rebuilder. Even with a lesser warranty, you could go directly to the people who did yours......
Now in USENGINES defense, They do allow their warranty to be covered by you taking the engine to a local repair/machine shop and they allow something like $45/hr for repair of a workmanship or part failure problem......They do want to speak directly to the shop and I presume they would send parts etc for the repair.
I called them asking about replacing my stock (330hp) 454 with a (425hp) 454 and I think that when I'm ready to do it I'll use their engine since they're so close by.
If you want to see the warranty, you will have to ask them to send it to you. They do not seem to post it on their site.
Regards,
Rick
windsors03cobra
Local Napa machine shoppe if possible or other reputable machine shop, support local folks. Plenty of folks rebuilding motors with good results no need to ship across the country. $5,000 buys alot of 502 rebuild.
HT32BSX115
I hope you're getting a little more on the core charge!
The "core" for a 454 is $1k.
I didn't ask about the 502 since the 502 rebuild price was almost DOUBLE the price for the 425hp 454 ($2995) and you have to supply the core.
I would expect them to offer MORE money for the core!
If you do it, please post your performance results here! You're going to get the engine I want to put in front of my Bravo III in my Four Winns 211 Liberator!
Cheers,
Rick
They are giving me 1000 for the core.
This is the quote they gave me:
$4195 for the 425hp 454 - 1000 for my 502 core
$600 to dress the motor (my 502 is fuel injected so they are going to convert the fuel system to carbureted)
$750 for carburetor and intake
$500 shipping
Total: $5045
HT32BSX115
$500 shipping
Total: $5045
Ok, The engine you're getting is:
[FONT=Arial, Helvetica, sans-serif]7.4 Magnum 425 h.p with 2 1/2" intake ports ...... [/FONT] [FONT=Arial, Helvetica, sans-serif]$3,195[/FONT] + $1000 core charge.
I would have thought they would give you a little more for the 502 core.
How much will they give you for the Mercruiser fuel injection system (you're keeping it right? You can easily sell it on ebay for $1000 or more!!) .....
There's no conversion required. You pull the MPI system and manifold, and replace it with the carb+intake manifold.
I was quoted basically the same price. ($2995.00 for the 2" intake model Although I would probably opt for the 2.5" like you)
But there was no "dressing" ......... I would take them my 454 core, long block and bring back the same.
If you're giving them your Mercruiser MPI system, you're giving away an extra $1000 if you don't keep it.....
There's not much to "dress" ...... you simply pull everything off your old engine and keep it. Bolt it all on when the"new" engine comes in the mail!!
I would keep the $600 and dress myself ;)
I would take off the fuel injection system before I sent them the engine
I have attached a copy of the 7 year 500 hour warrenty that they provide:
U S ENGINE INC
8504 S. 228TH Street Kent, WA 98031 253-852-3263
*******TIGHTEN INTAKE MANIFOLDS 7 TIMES or pistons will detonate*******
WARRANTY: Most marine engines built by US ENGINE INC come with our 7 year 500 hour warranty, limits and exclusions are listed below Please review them. We recommend for long life to replace your raw water pump, all tune up parts, belts and hoses. Please change your oils every 60 hours or once each year to keep your warranty effective. If you need installing help please call or visit our website.
To receive your 7-year warranty you must register your warranty by mailing a copy to our factory within 45 days of purchase date & first oil change 1 to 8 hours.
Non-registered warranty will only have a 6-month warranty.
Marine engines: 7 years or 500 hours against defects in material and workmanship. After 1 year there is no coverage for labor costs or shipping.
Oil seals & installed gaskets 6 months. Your warranty coverage is for the engine only. Engine installation warranty on engine installed by us engines is 1 year this does not exclude our listed engine warranty.
Warranty process: Call U.S. ENGINE 800 542 3211 or the installer so we may determine what is wrong and how to further proceed. Damaged engine or parts must be returned for warranty claims. We will need your oil change records. There will be no warranty coverage unless you contact us first for authorization and parts returned.
Labor coverage: Labor for repair shops is limited to $55.00 per hour based on factory time or reasonable time as agreed to before any repairs begin. All defective parts must be returned for credit or payment. Labor only covers our engine, no diagnostic time or other repairs.
We do not cover. Repairs that were not pre authorized. Damages caused from overheating, freeze cracking, operating with low or with bad oil, bearing thrust failure, piston damage or damages caused by the customers and installers.
Owners Name___________________________________________________________
Address_____________________City_________________ST________Zip_________
Boat Vin ___________________Make________________ Year________Size_______
Purchase Date_____________Millage______________Installer___________________
WARRANTY NO. ___________________ ENGINE NO. _______________________
