Use loctite 271 on rod end cap bolts?
Daphne444
I am in the process of replacing a couple of pistons on a 1990 90hp Force using Frank's through the reed opening method (Thanks Frank). I am almost at the stage of putting the new piston in and I was wondering what should be used to secure the rod end cap bolts when I torque them up. I have read and heard people mention Loctite 271 (red) but when I read the datasheet on it, it says that to disassemble bolts that have used this you have to heat to 250C. I know I did not have to do this to initially remove the bolts. Is this what I should use, or should I use something like the blue (242) loctite?
I hope that I never have to remove the pistons again after this, but if I do it would be nice to actually be able to do it.
Thanks
jerryjerry05
Re: Use loctite 271 on rod end cap bolts?
You don't have to heat them to remove them.Use the RED .Jerry
Matthew A.
Also, be sure that you don't reuse the bolts. Use brand new ones that have never been torqued. And yes...use the red.
