Re: used evinrude 150
awarm comp test wasnt done just a cold. all cylinders except one read 92, the last one fluctuates<spelling> between 32 and 92. have sprayed wd40 in all cylinders turned over by hand to distribute and let set. after a couple days went back and sprayed decarb turned by hand let that set. then squirted 20cc of 2cycle oil and turned by hand and thats the way it sets til i can get the ignition switch on the boat changed. have someone coming over to check all electrical systems because of corrosion from boat sitting for a year and a half. lower unit was clean when drained using a strainer. would keep if boat wasnt rated at 125hp.
