reelfishin
- Mar 19, 2007
- 3,050
I'm looking at a used Mercury 200, a 1970 model with Thunderbolt ignition.
It was supposedly rebuilt two years ago, and the gaskets and appearance sort of support that. It was at least dissassembled since all the gaskets look new, and most all of the bolts are brand new shiny stainless steel. The motor is on a flat bottom boat up in the mountains, so I doubt if its ever seen saltwater too.
I did a compression test, both cylinders show 121 psi, the lower unit looks new, and the fluid is clean, not milky, but not new, the prop is fairly new but has seen some use. I test ran it, it was hard to start but once it was running it ran strong. It did smoke a lot, but the fuel in the guy's tank looked dark, like it was way over mixed with oil.
The motor really took a while to start, it acted as if it needed more choke, or like it wasn't gettin fuel yet the primer bulb was rock hard. I ran the motor on the lake there for about 1/2 hour with no problems and subsequent restarts were no problem. It may well have been the first time it ran this season too. The plugs are new, the wiring harness also looks new. The carbs both look like they've been just done, everything is super clean.
I've been warned about the Thunderbolt Ignition and 'switch box' and stator by a local dealer. I currently have a Merc 400 which I use on another boat that's been great.
If an expensive part of the ignition was to fail, can these be retro converter to points? I've been told that they made both versions in these years?
The motor number is 2892688, it's a short shaft with remote control and it also has a tiller on it. I'd like to run it as a plain tiller motor, no controls, but still make use of the electric start. Can I move the start and stop controls to the motor? There's a plastic plug where the shut down button would be on a plain tiller motor. This function is done with the ignition switch . I don't care about an ignition switch, a push button is fine.
The seller wants $300, firm, He's got $2344 in receipts for the overhaul from 2007.
Does 121 PSI on both cylinders sound right? (My Merc 400 (40HP) has 145 on both cylinders and is all original). (Both motors were checked using the same gauge)
