Uses for Vodka
Twidget
Vodka. <br />Pretty interesting....<br /> <br />1. To remove a bandage painlessly, saturate the bandage with vodka. The <br />solvent dissolves the adhesive. <br /> <br />2. To clean the caulking around bathtubs and showers, fill a <br />trigger-spray bottle with vodka, spray the caulking, let set five <br />minutes and wash clean. The alcohol in the vodka kills mold and <br />mildew. <br /> <br />3. To clean your eyeglasses, simply wipe the lenses with a soft, <br />clean cloth dampened with vodka. The alcohol in the vodka cleans the <br />glass and kills germs. <br /> <br />4. Prolong the life of razors by filling a cup with vodka and <br />letting your safety razor blade soak in the alcohol after shaving. The <br />vodka disinfects the blade and prevents rusting. <br /> <br />5. Spray vodka on vomit stains, scrub with a brush, then blot dry. <br /> <br />6. Using a cotton ball, apply vodka to your face as an astringent to <br />cleanse the skin and tighten pores. <br /> <br />7. Add a jigger of vodka to a 12-ounce bottle of shampoo. The <br />alcohol cleanses the scalp, removes toxins from hair, and stimulates the <br />growth of healthy hair. <br /> <br />8. Fill a sixteen-ounce trigger-spray bottle and spray bees or wasps to <br />kill them. <br /> <br />9. Pour one-half cup vodka and one-half cup water in a Ziplock <br />freezer bag, and freeze for a slushy, refreezable ice pack for aches, <br />pain, or black eyes.. <br /> <br />10. Fill a clean, used mayonnaise jar with freshly packed lavender <br />flowers, fill the jar with vodka, seal the lid tightly and set in the <br />sun for three days. Strain liquid through a coffee filter, then apply <br />the tincture to aches and pains. <br /> <br />11. Make your own mouthwash by mixing nine tablespoons powered cinnamon <br />with one cup vodka. Seal in an airtight container for two weeks. Strain <br />through a coffee filter. Mix with warm water and rinse your mouth. Don't <br />swallow. <br /> <br />12. Using a q-tip, apply vodka to a cold sore to help it dry out. <br /> <br />13. If a blister opens, pour vodka over the raw skin as a local <br />anesthetic that also disinfects the exposed dermis. <br /> <br />14. To treat dandruff, mix one cup vodka with two teaspoons crushed <br />rosemary, let sit for two days, strain through a coffee filter and <br />massage into your scalp and let dry. <br /> <br />15. To treat an earache put a few drops of vodka in your ear. Let set <br />for a few minutes. Then drain The vodka will kill the bacteria that is <br />causing pain in your ear. <br /> <br />16. To relieve a fever, use a washcloth to rub vodka on your chest and <br />back as a liniment. <br /> <br />17. To cure foot odor, wash your feet with vodka. <br /> <br />18. Vodka will disinfect and alleviate a jellyfish sting. <br /> <br />19. To remove cigarette smoke in your home or office mix one part vodka <br />and three parts water and spray the clothing, then launder and let dry. <br /> <br />20. Pour vodka over an area affected with poison ivy to remove the <br />urushiol oil from your skin. <br /> <br />21. Swish a shot of vodka over an aching tooth. Allow your gums to <br />absorb some of the alcohol to numb the pain. <br /> <br />After reading this, can you believe that some people drink the <br />stuff?
brother chris
Re: Uses for Vodka
I had to do #21 for my tooth last week. But I used rum instead. It nums the pain. Just let it soak in your mouth for a couple minutes and you can't feel your teeth. Do that all night and you won't feel anything. :eek: <br />My dentist appointment is not for another couple weeks. <br />Maybe I will stick with the rum after reading this about vodka.
62_Kiwi
Re: Uses for Vodka
Looks like they need to sell it in a spray can...could be almost as useful as WD40... :D
Barlow
Re: Uses for Vodka
Sooooo... If you drink vodka to the extent of vomiting... you shouldn't need to waste any unconsumed vodka to clean the stain,right?<br /><br /> :D
BoatBuoy
Re: Uses for Vodka
Pretty expensive uses for which rubbing alcohol will suffice in most cases.
PatPatterson
Re: Uses for Vodka
That only makes sense. <br /><br /> Vodka, It isn't just for breakfast anymore!!!! <br /><br /> :D :D
Elmer Fudge
Re: Uses for Vodka
Originally posted by 62_Kiwi:<br /> Looks like they need to sell it in a spray can...could be almost as useful as WD40... :D
or maybe Seafoam :D
neumanns
Re: Uses for Vodka
Looks to me whoever compiled that list missed one. I've been told it is also a cures what ailes ya. Purly medicinal of course.
rolmops
Re: Uses for Vodka
I have it from reliable sources that after consuming enough vodka,every woman looks beautiful.If they don't, it simply means that you did not drink enough.
tomatolord
Re: Uses for Vodka
Dont do #9 though it can be dangerous...<br /><br />The problem is that most freezers are around 0 degrees. So the slush when it comes in contact with your skin will freeze your skin and cause even more damage.<br /><br />The correct way is to use crushed ice and then add water to the bag so that resulting ice actually warms up.<br /><br />and<br /><br />rolmops they are called vokda foxes
wajajaja
Re: Uses for Vodka
TRY VODKA ON HEMROIDS,<br /><br />fun to tell someone else to try it! :D
Elmer Fudge
Re: Uses for Vodka
Originally posted by wajajaja:<br /> TRY VODKA ON HEMROIDS,<br /><br />fun to tell someone else to try it! :D
When in a drunken state that'll take some time in preparation :D
ae708
Re: Uses for Vodka
I'd rather drink the vodka and use cheap alcohol for all the rest.
ED21
Master Chief Petty Officer
Re: Uses for Vodka
Where's my tomato juice & tabasco?<br />I have an urge for some reason.
Twidget
Re: Uses for Vodka
Or at least make you forget what it was.
lakelivin
Re: Uses for Vodka
this reminded me of an experiment some kids did on cheap vodka. filtered it through a brita filter 4 or 5 times and claimed it was improved to the point of approaching a ketel one or grey goose. haven't tried it yet myself, but think I will next time I've got a group of friends over. See link for experiment details (look down the page a screen or two). <br /><br /> http://www.ohmygoditburns.com/
deputydawg
Re: Uses for Vodka
So what you are saying is that Vodka is actualy good for you?<br />Years ago the story goes that a football coach in an effort to keep his players from drinking during training poured a glass of whiskey. He then dropped a worm in it. The work promptly died, so he asked his team after seeing what it does to this worm, what does that tell you about what it does to your body. One team member spoke up saying well coach if we drink enough whiskey we won't get worms?<br />So if we drink enough vodka we will actually clean and disinfect our bodies making us the epitamy of health?
