outboardnut
- Oct 27, 2006
- 323
Ok so I've got a dyno. It's the international dyno, some call it K and O.
Trying to learn and figure everything out with it.
One thing I don't quite get is peak output. According to the manual it comes with they talk about peak output being less than peak RPM.
So if I dyno a motor, lets say a 150 HP engine, and it starts generating 3500 PSI at 5000 RPM, and drops to 3400 PSI at 5500 RPM, then 3300 PSI at 6000 RPM, should shoot for a prop that will load this engine @5000RPM and call it right?
I have always thought more RPMS will equal more speed regardless of whatever PSI the thing is generating on the dyno. Isn't this more of a torque reading they are giving?
My only conventional thinking on proping a boat is if the mfg's listed operating range is 5k to 6k, prop the boat to 6K and you are getting every pony she has.
According to internatinal dyno, they are saying you want to hit it at the peak output which may be less than peak RPMS?
