Caddiehack
- Jan 2, 2011
- 4
I had the "privilege" of replacing a cracked block this spring due to an unusually hard freeze. I have a 22 ' Regal, kept above the water in a boat slip. I am looking at an electric heater placed in the engine compartment that auto turns on at 40 degrees. The engine is a Mercruiser 270 HP I/O. Assuming I size the heater correctly for the compartment, should this be sufficient to avoid the same problem I had last winter, freezing up the engine?
Thanks,
Thanks,
