Using a Vacuum Guage AQ131D
user-name
Can it be used?
Im getting the Point Dwell & timing dialed in. Runs a lot better thanks for all the help.
Plugs look Almost OK but not quite right. So Im looking at the carb, maybe a little rich. So I get out my vacuum gauge.
Am I blind I cant find a vacuum port.
user-name
Re: Using a Vacuum Guage AQ131D
I found this http://c777913.r13.cf2.rackcdn.com/44pa1_rebuild_instructions.pdf
On page #3 I have what kind of looks Late version
P#4 tell its 2 turns for the Idle RPM
Then 9.5 for the air fuel mix
Im no carb expert by any means but those screw turns seem to me like a ruff in. Like using a feeler gauge to set the points.
I all ways used the vacuum guage like a dwell meter with a target of 20-22
PiratePast40
Other than linkage, there are only 2 adjustments. Idle mixture and idle speed.
jerryjerry05
Not positive but I don't think there is a vacuum port on the 4cyl.
