Using cabosil, wood flower, talk with poly resin for filler/fairing?
Darren Nemeth
I just ran out of watertite interlux filler! lol
Spent the day filling in holes/ gouges with Wiatertite and only need to fill the transom and one small area on the bottom now.
The epoxy primer I am going to use is Interlux InterProtect 2000E and it says don't apply directly to fiberglass.
The poly resin and filler mixture is fiberglass! :eek:
What do you think I should do?
Yacht Dr.
Re: Using cabosil, wood flower, talk with poly resin for filler/fairing?
It should be fine m8.. I use it all the time over my glass repairs.
I put 5 coats on to get my 10 mils
Make sure you hit your window on the final coat of IP2000 and first coat of bottom paint ( Im assuming your painting ).
YD.
Darren Nemeth
Thanks for the answer.
I mix up some cabosil and poly to finish off my repairs,then.
Yes. Roll and tip painting. :) I'm using the 2000E for top and botom sides and Petit EasyPoxy for top and bottom, also. This boat is mainly for show and occasional riding on the water. :)
I bought more than what I need of every thing BUT the watertite interlux filler. lol!
