Using Ignition leads from a car
ozkor
Does it matter if I use ignition leads from a car on my outboard is their any difference.
gm280
Answer to your question is yes and no. If the car ignition wires are wire core, I can see it working okay. However if they are resistive core wires, I wouldn't use them. But if you are going to buy wires, why not just buy the proper type wires for your OB engine and no worries at all then... JMHO
jbcurt00
I think boat ignition leads are tinned wire, and i'm sure auto wires arent.
Tinned wires are intended to keep corrosion at bay.
Use the correct wires
GA_Boater
The OEM plug wires for the antique OB in my sig were marked Packard 440. It's wire core and has been used in cars for eons, I found Packard 440 in bulk at O'Reilly for 69 cents/foot. Now I don't have an eerie glow from under the cowling and she runs a heck of a lot better. :smile:
99yam40
A lot of outboard motors have wires that are not changeable. have to change the coils to change the wires.
So it might be a good idea to identify what motor you are talking about changing wires on.
jbcurt00
Duh, when I read ignition leads, I thought: wires from the key back, not under the hood/cowl wiring.
