V-4 Piston to Block CLearance Question
Coach955
1996 112 HP Evinrude. I know when measuring piston to block clearance you do it at the skirt. Do I need to be concerned about the wear / clearance measured just above the top ring land on th episton? with keystone rings in this motor it seems this should have a maximum clearance allowed? PLease educate me.
Thanks
Faztbullet
If you are rebuilding measure the bore first,,,if its .003 over spec it needs bored. The pistons are slightly tapered with top being smaller than skirt. What are your measurement's????
Coach955
Largest bore is only .0025 over spec of 3.500. all are within .0015 of being round as well. Skirt clearances are measuring from .005 to .0075. But clearance above the top ring land approach .020 - .025.
Thanks
Faztbullet
It measuring out of round should be bored as tolerances will increase with heat also pistons are out of spec. Just bore it .020 as you need new pistons anyway, both you and the engine will be happy this way. If you decide just to try pistons use the Wisecos as they work good in sloppy holes...(that sounds dirty)
