v belt squeling
fishingman220
so i am younger and have not really messed with v belts. on my 96 5.7 it has v belts and it squels right at startup for maybe 2 min and then it is quite. what do i need to do to make it go away? is it loose? do i need new belts? am i screwed? its just annoying and i was hoping i could make it go away.
Don S
Re: v belt squeling
Look at it, check it. If you can't tell if a belt is loose, then you probably need to find a mechanic to keep your boat up for you.
fishingman220
Re: v belt squeling
it is tight, when i put it on i put a pry bar on the acc. when i tighten them down, i dont see how you could get them any tighter
achris
More fish than mountain goat
Re: v belt squeling
:eek::eek::eek:
Too tight!?!?!?
Download a manual for your engine and look at the right way to tension a belt. Too tight and you'll destroy the bearings in the alternator and water pump....
Chris.......
Re: v belt squeling
Ayuh,... That's the Alternator, under Load.... How rusted are the pulleys,..??
fishingman220
Re: v belt squeling
they arent to bad, the worst is the crank pully and its not bad at all, just alittle surface rust, but i will check the rest and sand them
cr2k
Re: v belt squeling
Your belt is probably glazed and worn. If not your battery is going bad and taking a big hit when you start. The squealing is the load on the alternator trying to recharge the battery. It goes away as the battery get charged back up.
fishingman220
Re: v belt squeling
batteries are new and charged before i put in the boat just to make sure they had full charge
