Rancherlee
- Jun 6, 2006
- 621
I need to overhaul my 88' 88spl I bought a few weeks back due to excessive wear on #3 cylinder. The sleeve that was installed on #1 cylinder seems to have been installed too deep as its sits .015 lower than the block and has trouble with blowing the headgasket. I was wondering it if ok/common to mill upto .015 off the block or if I should look for another block to use. Currently mine is standard bore with a sleeve in #1. I'm wondering what years/size cylinder blocks I could use with my engine If I decided to find a good reuseable block to base my overhaul on. I may have access to a 81' 115hp for very cheap that I could also use if the block will work.
