1997 130 HP Oil Transfer pump quit again. It did in about 2000, change the lift pump and everything was fine.
Now it has quit again and I can't Remember how I figured it was the pump and not the wiring.
So here is what I know. Engine tank gets low, Engine cuts out, the first time I opened the hood, tried the emergency switch (key on) wiggled some wires, the Engine tank filled. This year Warning came on, nothing happened with the emergency switch. Filled the engine tank by removing the float and ran home.
Pulled the Boat tank, ran 12V directly to the Blue and Brown wire. Nothing happened no pumping. Pulled the electric motor off of the pump and the magnets have fallen off of the case. They are just loose in there. They look like they were glue to the case but no longer are.
I would think that is my problem, But I want to make sure before buying a new transfer pump.
Thanks.
Thanks.
