Johnson 140
- Mar 2, 2011
- 12
I was concerned about the flow coming out of the 2 exhaust ports (there isnt a tell-tale) and I didnt know the age of the impeller, so I bought a water pump kit for my 77 140 V4. Once I got inside the old impeller looked good. I went ahead and replaced the cup, housing, impeller, o-rings, and the rubber grommet that goes around the output and saved the old ones for spares.
I fired her up on the muffs and there is no water coming from the ports for the first 5-10secs. After that it began to spit out small amounts with the exhaust. I turned off the hose and noticed water draining from the housing between the LU and cowl. There are small drain ports that drained water for several secs after I removed the muffs.
My first thought is I misaligned the pump output with the copper tube upon reassembling the LU and its pumping that housing full. So how can I check to see if Im pumping water up to the engine? I do not have a tell-tale... There was a thread yesterday about a v4 crossflow that included pics and he had 10X the flow I do coming out of the exhaust ports.
