V6 mercruiser engine removal procedure
henry1357
Hi l
Looks like I have to rebuild my engine, what is he correct procedure.
Obviously I will remove all cables and pipes connected between boat an engine.
Do I then remove manifolds, undo engine mounts and lift out or is it more complicated
Thanks in advance
Henry
series60
Re: V6 mercruiser engine removal procedure
Hi l
Thanks in advance
Henry
Remove the outdrive first. Do everything you mentioned above. There are two rear mounting bolts that have to come out and two fwd engine mounts. Remove the top nut from both fwd mounts. You can leave the manifolds on but removing them will make for a lighter lift. If you have room and strong lifting platform, leave them on til the engine is out.
henry1357
Hi thanks
Ok doesn't sound to bad
When putting engine back does it need to be allined or will it just go back on mounts as I will not need to move the adjusters
Regards
Henry
series60
Hi thanks
Regards
Henry
The single most important item, both after engine install and yearly maintenance is: Engine alignment!
Get a manual for your engine/outdrive from the 'adult only' section. Read them both or you will probably be doing the job again to replace the engine coupler.
henry1357
Hi
Yes have read how important alignment is have seen a tool on eBay so sounds like a good idea to buy one
Regards
Henry
thumpar
Yes I would recommend it even if you didn't remove the engine. I bought one off ebay and use it every season before I reinstall the drive.
