V8 Fuel supply Modified ??
MarkV_Deep6
Hello<br /><br /> I am installing the new 4 wire VRO pumps to my 92 300 HP Johnson.<br /> It appears that the fuel supply lines were modified by the previous owner. After the VRO Pumps there is a cross over supply H type fitting that was constructed to provide supply from either pump should one fail.<br /> I can tell this is not a factory setup as the parts are hand made. <br /><br /> The question is would you keep this in the set up the fuel system? It's been running fine and has no fuel delivery problems.
Dhadley
Re: V8 Fuel supply Modified ??
That was the way OMC did it. The parts may be home made now but that was the way it was from the factory.
MarkV_Deep6
Thanks Mr Dhadley!!! Your expertise is greatly appreciated. I also noted in a photo of a V8 that there was a white device just above the lower pump. It looked almost like a filter. Do you know if that's what it was, or am I missing something?
Dhadley
That probably was a filter but if it's not there I wouldn't worry about it. Just make sure you have a good one in the boat. The less fuel restrictions the better. Nothing but straight 3/8" ID fittings, no bulhead connectors, no primer bulb, no hose smaller than 3/8" ID.
