Value Adjustment Schedule Question
creeks11
How often should the value adjustment be checked on a Mercury 15hp.
I bought the motor new last year and have now run it for a normal season of use. The manual says once a year. Is that excessive????
Thanks
tashasdaddy
Re: Value Adjustment Schedule Question
consult you manual.
j_martin
How many times are you going to ask the same question and ignore the answer?
creeks11
The only answer I see is the one posted here. Do you have others that I have ignored??? Please advise.
The intent of my question was to get some non dealer input to see if the once a year value adjustment was really necessary as per the owners manual. In some areas owners manuals can be a little excessive at times when it comes to maintenance of some items.
Thank you for the warm welcome to your board.
Update: I see what is going on. I posted this question on another section of the boards and then reposted it here after I noticed the low traffic in the first area. Evidently my first posting was moved into here so it came up twice.
