John from Madison CT
- Oct 14, 2001
- 176
Greetings,<br /><br /> I'm looking at buying a spare motor for my newly acquired Boston Whaler Montauk. The motor I found is a '89 Yamaha 90HP motor that was only run in Freshwater. It appears to run very well and has no corrosion. The compression is also good with very little variation between cylinders.<br /> I was wondering if you guys had any opinions as to the value of this motor. I believe I can get it for $1300 with Controls and Prop.<br /><br /> Your expert opinions are very well appreciated.<br /><br />Thank you,<br /><br />John
