Valve Adjustment on 5.7L Vortec
Status
Not open for further replies.
76SeaRay
Ok, so read all the threads about 3/4 versus 1 turn past zero lash. However, from what I found from Comp Cams, they say to 1/8 to 1/4 if the engine spends its time at high RPM and 1/4 to 1/2 turn for average "street driving". I am guessing their reference to the street would be applicable for boats. My machine shop was asked me if I was going to use 1/4 turn (he builds race engines) and I told him I would likely use 1/2 turn. I am using the Xtreme Marine 264 cam with .488 and .495 lift. The engine is going in a cruiser in large lakes so running low speed, medium cruise, and for long runs across the lake at high RPM. What is everyone's thought these days on 1/2 turn? Is there a technical reason to go tighter than recommended by Comp Cams?
Thanks...
If you have stock non-adjustable valve train, you tighten up to 30 lb-ft
If you converted your heads to adjustable valve train, then 3/4 turn past zero lash
So......what mods were done to your heads?
76SeaRay
Stock heads but improved valve springs, Comp Cams hydraulic roller cam, and Comp Cams 1.50 roller tip rockers on 3/8 rocker studs.
so you converted the heads to adjustable valve train then.
did you go with thread in studs, or do you still have the press-in studs that are stock? if you are running the press-in, you will need to monitor for the studs pulling out with the different springs
76SeaRay
No, they never were non-adjustable. Stock 1996 vortec uses non-roller tip stamped steel rockers on studs. Yes, the heads were tapped and new screw in studs added in place of press in studs.
AShipShow
Didnt know Merc had vortec motors yet in 96... you sure it's a vortec head? How many bolts on intake manifold?
76SeaRay
I am scratch building the engine. Yes, it is a true vortec set of heads on an 880 block.
so, 3/4 turn past zero lash.
Dentar
I just adjusted my valves on my 1997 mercruiser 5.7 with vortec heads.
Went with 3/4 turn past zero lash as adviced. Once done i comptested the cylinders, turns out 0 compression on all of them !?
Came back here and read TS post with 1/4 + 1/2, so i backed all valves 1/4 turn and lord behold compression is back! went back another 1/4 and compression increased 3-10 psi on each cylinder. so in the end im 1/4 turns past zero lash.
Status
