Valve covers and intake.....polished or black wrinkle paint
Finishing up the motor.....valve covers and intake.....polish them and seal them, or black wrinkle paint?
then the second question....tall valve covers, or a spacer under the stockers.....
Bob_VT
Stock ones will emphasize the intake manifold making it appear higher.......... the high covers will make up for the intake and the entire motor will look larger.
If there is an increased oil pan and increased oil capacity I would go with the higher ones otherwise I would keep the lower ones to help with oil return.
Tnstratofam
For finish I prefer the polished look. I think the crinkle look is neat but polished is more classy/hot rod in my opinion. I agree with Bob on the valve covers.
The Admiral wants polished as well......guess I know what I am doing the next few evenings.
The taller Eddie Marine valve covers are for clearance of a rocker stud girdle. if I had a bigger motor, blower and dry exhaust, I would need the clearance. since the internals are forged and the CR is about 9.5:1, I could always drop on a small blower......:D....and proceed to shred the drive :facepalm:
Stock valve covers would need a 3/8" spacer to have adequate room for the existing rockers. the rocker locks currently hit the underside of the covers.
southkogs
Could match the valve covers to the block and then do the manifolds polished ... with the chrome lookin' spark plug wires. I think it's the black that I don't like for the covers. Front looks good.
manifolds are already wrinkle black with polished stainless elbows.
MTboatguy
Unless you have the ability to bake the wrinkle finish, it will eventually start flaking off and it is so important to make sure that cover is 110% clean if you are going to spray yourself.
Polished bright chrome is always classy and fits in with most projects.
The admiral hates that i stink up the house baking parts.......
No Title
ok, so spent $100 at harbor freight to get an electric die grinder, a speed control, a polishing kit, etc......the die grinder lasted under 120 seconds. it started to smoke 20 seconds after I turned on the switch. have some spectacular video of smoke pouring out...
what $100 at harbor freight looks like (with a 20% off coupon)
first pass at cleaning up the valve cover
cleaning up the intake
