Midnight Thunder
- May 29, 2007
- 27
Thank you to all for assistance with the lower end rebuild.
Re: Mercruiser 165 inline 6
I'm having problems with the valve lash. The orig problem was knocking in the lower end - fixed with machined crank and bearings all around.
I idle the motor at 500rpm to avoid oil spray and while warm and running adjust the rocker arm bolts till they stop clicking and then 1/4 turn. I have also tried the cold not running method as well.
Problem is, when I rev the engine up - she starts clicking. For sure it's coming from the top end. I adjusted each rocker arm by 1/4 additional turn - seemed to quieten her down but still at higher rpm and especially when she's running at full temperature, it really starts clicking.
I don't want to overtigten the rockers for obvious reasons and am worried about possibly a failed lifter or two??
Does the warm/running method need to be done at higher RPM?
Your advice and thoughts are appreciated.
