vapor / high water combo detection bilge alarms?
Bounce19712
Hello! is there a combo alarming system for bilges? or do I need to buy two separate alarm/detector systems for my old 1982 454 day cruiser's bilge?
thanks
jbcurt00
Vapor?
Fuel?
Alarm? So you dont have to run the bilge fan before start up?
Or more of a typical auto bilge (for water) coming on and off regularly as needed automatically when it detects fuel vapor?
Bounce19712
I want alarm siren and warning light for instrument panel for high water and fuel vapor in bilge if there is such a thing.... whether it controls the blower or bilge pump is not required / icing on cake.
I don't have a fuel vapor detection system currently. the boat had a sniffer but it is inoperative. the blower is manually operated right now. the bilge pump has an internal flapper on it.
with family on boat/skiing, pulling tube (multiple engineshutdown/crank cycles), camping over night....I would feel better with high water alert and anytime vapor alarm detection
thanks`!
eta: doesn't need to be automatic pump or blower on... is there a combo alarm system? or is it buy a system for each issue... (high water/ explosive fuel vapor)
If I have to buy two systems...one for fuel vapor with auto blower turn on AND highwater detection with auto bilge on...so be it.
looks like 2-300 dollars for each type or system....
the boat is an old 26 footer
Vapor?
Fuel?
Bounce19712
found a combo system..THANKS
AMRM-SA-10XL * Marine Fume, Fire, Flood Detector
ETA: I think I'll keep the two separate.... thanks again for any input!
gm280
I can somewhat understand an alarm for vapors...maybe, but why an alarm for bilge? I mean it can be a self serving bilge system and then you don't have to worry about it at all. :noidea:
NYBo
No Title
I simply hooked up an indicator light to the power for my bilge pump. It lights up when the float switch activates or when I use the manual position on the control switch.
