Tom Basile
- Sep 8, 2003
- 5
I have an older boat that was repowered with a 1999 merc 350. The boat is used mostly for fishing.Any time i let it idle for aprox. 1/2 hour<br />and then power it up it dies.Checking the carb. showes no fuel.The fuel path is from the tank to a water seperator to a carter electric low presure fuel pump to a holley carb.The fuel pump uses a oil presure switch to feed it 12 volts when the key is in the on pos and oil presure is above 8 lb.{ must have oil preasure to run pump ].This switch is ok.If I let it sit for aprox. 1/2 hour than turn key to on and jump switch I will get gas after 2 or 3 min.At this point I can start the boat and is fine until I idle again for say 1/2 hour.??
