LubeDude
- Oct 8, 2003
- 6,945
I pride myself in trying to keep things up as best I can, but!!!!!!!!!!!!!!!<br /><br />I changed the oil on my Ranger yesterday, I jacked the drivers side up and placed a jackstand under it to gain access to the drain plug and noticed that when I did, the drivers side wheel seemed to move a bit when I lifted it off the ground. So being currious about why that might be, I grabbed the tire and wiggled it, Wow, its loser than it should be. Wheel bearing?????????????? Yep, so what turned out to be just an oil change turned into new wheel bearings and seals and rotors and brakes. I just repacked the bearings about 30,000 miles ago but I did notice that the truck has been following the ruts in the road a bit more than usual. Allways something!<br /><br />So, when was the last time you checked your wheel bearings????????????????????
