Re: Venom 200 lower water seal
That would be nice but that feature is not on these engines, they will run fine with no water pump and melt pistons in short order.
The overheat sensor in the heads forces the ignition into SLOW mode, 2500rpm max.
You obviously have some cylinders not firing,
just for giggles...
try disconnecting the shift interruptor switch on the starboard side, down low , its coupled to the shifter cable mechanism, follow the wires and unplug them.
Test it like that. If it fires on all cylinders the shift interrupt switch is stuck or shot.
One bank of cylinders shuts down momentarily every time you shift into neutral, but if its stuck/bad you'd lose spark in half the holes.
If its not that then you have to test with a gap tester for good blue spark on each plug wire, don't bother using a sparkplug to test, it doesn't work.
How do the coils look , good?
If you didn't remove coil from the block you cannot tell if the potting is cracked because it happens on the back, really examine them closely and clean the mounting surfaces with sandpaper.
