vent and drain plugs
lepfrog
Where is the vent screw and the drain screw on a 1986, 85hp. force lower unit. I see 2 screws in the top and 2 in the bottom
emoney
Re: vent and drain plugs
Don't touch the one on the "bulb/prop shaft", that's the gear shift pin. You won't be happy if that comes out. Usually, the plugs are right under the cavitation plate for vent, and below the prop shaft for the drain/fill.
jerryjerry05
First is drain plug.
Probably an allen head set screw.
Top is fill and the vent for escaping air.
The very bottom is the drain.
The slotted screw is a pivot pin for the shifter.DON"T TOUCH!!
