pecheux
- Jun 9, 2006
- 1,200
Good day,
I have this small 12 footer boat + 6 hp sitting at a dock with the gas tank sitting in the boat all true the summer months. I had a non vented (or automatic vented) OMC metal gas tank that has no vent screw on the cap therefore I presume that no water could infiltrate the tank and mix with gas/oil when it rained on it.
Now I would like to change the tank for a newer plastic model but they all have a venting screw on the cap that needs to be a the open position while running, more so when under the sun I guess.
Question is: Can water infiltrate the tank via the venting hole while it rains on it ? or is there something in the cap that prevents that from happening ?
Thank you
Thank you
