vented gas tank
Brento311
Hi, earlier I posted about having a piece of junk elgin 7.5 HP because it kept cutting out on me. Well, a friend of mine told me it might be because I didn't have a vented gas tank. I got home and looked at the 40 year old tank, and it doesn't have a vent at all! What do I do, just take the cap to the tank off? Any suggestions would be very helpful!
Fouled Plug
Ensign
Re: vented gas tank
Brent, I'm 99.9% sure you have a metal tank. It may have a vent built into the cap that is malfunctioning, or no vent at all. If your Elgin has a fuel pump and draws from it, you will need some sort of air intake to prevent a vacuum. Either a vented cap, or a dedicated vent in the tank. You can test your friend's theory by running with the cap cracked, or waiting till the motor starts to stall and opening the cap.
Rock Man
Re: vented gas tank
Ya I would try to cracking the cap on the tank for a little air flow, but is this possible for the motor to shut down for not having appropiate venting??? :confused:
petryshyn
Re: vented gas tank
Ditto on Fouled plug<br /><br /><br />Yes rock man<br />if a tank that requires venting has no venting, it'll slow the engine down alright. Nothing allowed in means nothing allowed out. It'll slow you down(runs lean) according to how bad a restriction. Total restriction = engine dies.<br /><br />Brent311<br />How many hoses going to tank? One round hose? Two hoses side by side?<br /><br />>one round hose = needs venting (has fuel pump)try "Fouled plug's" test<br /><br />>two hoses = needs to be sealed, cap must be tight (has no fuel pump, relies on crankcase pressure)<br /><br />hope this helps somewhat... :)
Brento311
Re: vented gas tank
hey, thanks for the advice. The tank has a single round hose going to the motor. It is an old metal tank, and I believe it is a 2 gallon. There is no vent that I can see on it, and i don't think the cap is vented.
Fouled Plug
Ensign
Re: vented gas tank
You may be able to find a vented cap at your local boating supply place that will fit the tank. It may be less hassle to just get a new plastic tank with a vent, though. Try running the motor again with the cap cracked, and see if the old Elgin likes that better before you go shopping.
Brento311
Re: vented gas tank
This afternoon, I looked even closer at the old Elgin fuel tank and noticed that there is an air vent next to where the hose goes in...it's just a little screw next to the hose. What do I do to vent air in, just unscrew it all the way? Thanks
Fouled Plug
Ensign
Re: vented gas tank
You don't even have to back it out all the way, Brent. Just a couple turns from seated shoud do it. Let us know how your next trip turns out!
