Verado lower unit problem
brushhippie
This lower unit is actually on an 07 opti..anyway my buddy left the lower unit up and it froze and broke the carrier...no biggie...pulled it apart cleaned it up good and replaced the carrier....so he comes back in with it and you can move the shaft up and down...just slightly...and in and out as well...so I think I didnt get the carrier in all the way...so I pull it all apart again clean it up and put it all back together again...this time I built a spanner nut wrench and really cranked down on it...to the point Im afraid of ruining the threads in the housing...and still moving...just slightly...both in and out and up and down.....there were only two shims behind the rear shaft bearing...which is what the book shows...but Im thinking that the rear bearing just isnt seated all the way against the race....I am thinking add another shim?...speak to me gurus!...thanks
Dukedog
anytime "anything inside a gear case" or just tha case itself is changed from orginal it needs ta have end play and lash set up with tha right tools.......
brushhippie
End play and lash?....umm ok...seems to me there is no adjustment....oh well thanks I am sure I will get it worked out without any high dollar mercury tools...thanks anyhow.
Dukedog
take your pick on shims, ya got "several sizes" ta chose from and get after then......torque on tha big nut is about 210 ft. lbs if ya wanna know.........
brushhippie
I ordered a shim kit...I would think the play would equal the shim there abouts...I did need to know that on the torque, thank you very much...I believe Im well above that. I have rebuilt and repaired several lower units and never had an issue before this one....been lucky I suppose.
