- Mar 8, 2009
- 42,627
Got my manual today, yeah, have another problem
One trim cylinder on SB motor has slight trim cylinder leak and it's on the bottom. While I might be missing an area, I'm passing my hand all over it and only comes up wet on the bottom. This may have been caused by a user but don't see how and I was watching
Getting ready to bring boat back in the fall after canvas work. I raised the port motor using switch on the motor. Raised it up, extended the support latch under the motor and pulsed the switch until it just touched the latch.
A canvas shop helper did the starboard in similar fashion as I watched. Then there was a loud pop. Raised it back up assumed the plastic latch broke because everything else is steal and cast aluminum. Found nothing
Pull boat out in spring and see small amount of oil on the floor.
