wildmaninal
- Jul 14, 2007
- 1,897
Short story behind this question. I just got through installing a faria tachometer on my bass boat for my 1978 Evinrude 85hp model number 85950 I believe. I took this tachometer off of another bass boat hull I have out back. I had to replace the glass on the tach because the original was cracked. Tried to cut the glass myself but that didn't work to well. So I paid $2 at a local glass shop to have a piece cut out.
I hooked it up to my remote control wiring harness and made sure that it worked by running the motor on muffs before I drilled a hole in my console to mount it. Had the Johnson manual on hand while doing this. Nearly screwed up my wiring, I did screw up on my mounting location, it is not deep enough for the tachometer to sit in it hits the steering system. Didn't have much space to mount it otherwise, I figure I'll use a piece of plywood to hold the guage out away from the steering box in the back. Figured I would install it today and get it out of the way so I can test it this weekend when running under a load
. I just like hooking up the light for the tach by jumping a wire off of the speedometer light power wire, maybe I won't goof that up.
Right now the tach is set on 4 I believe. On to the question...What should it be set on?
