I have a 2001 merc 90, 4 stroke in which the voltage regulator caught fire, burning up several pieces under the hood including the CDI module. 1400 bucks later I have reassembling the engine and fired it up. It runs fine on muffs and is putting out 14.72v to the battery at idle. Service manual says that I should have no more than 14.5 to 15.0 volts being output from the charging system. What worries me is the voltage regulator was getting pretty warm after only a couple of minutes of run time. I realize that the regulator is equipped with fins for this reason but I wonder if the voltage regulator is being overworked and, even though this is the latest revision of regulator design, if the stator is putting too much out. Perhaps this is why the previous regulator caught fire?
I am just trying to make sure I have checked everything I can to prevent another fire from occurring, not to mention the crazy cost of the parts.
Thanks,
Chris
Thanks,
Chris
