Vertglas and Poliglow for person who can't buff
harrisg
I bought a 16' 1983 Invader that had been outside for 4 years. The mechanicals are now working and I'm ready to clean up the oxidized exterior. The problem is, I only have 15% left of one disk in my spine and a damaged wrist so going through the compound, polish and wax process that I've read about in the archives is pretty much out of the question for me. That leaves Poliglow or Vertiglas. <br /><br />I've read reviews by boating magazines on both products and all reviews indicated that Poliglow was slightly better than Vertglas. <br /><br />FYI, the color of the sides of the boat are a reddish orange and there are wide scratches where white shows underneath.<br /><br />Can anyone advise what product to use to add color to these blemishes?<br /><br />The info I've read about Poliglow and Vertglas make it sound like even someone like me can apply it. I'd like some info from those who have used either product as to the application, their opinion of the product and most of all, whether a screwed up geezer like me could apply it.
threedeesmax
Re: Vertglas and Poliglow for person who can't buff
From one gimp to another, I know what you mean. My spine is trashed too, and I'm partly paralyzed on one side. I walk with a cane.<br />I followed Mark42's advice and used Scotch-Brite pads and Comet powdered cleanser to remove the oxidation on my 1962 Red Fish Shark, doing it by hand, without power tools, one small section at a time. It was a real workout for me, but I rested when needed, took my time, and eventually got it done (in about three weeks' time). Don't get me wrong, it wasn't easy and it was painful, but worth it in the end - especially the satisfaction of having done it myself, for under $50, including polishes and waxes. Give it a shot - it works. Wayne A.
robpoe
Not trying to sound brash here, but if you're not able to do it maybe find a relative (nephew, cousin, something) who's a teen and offer to pay them to help out. Explain your situation to them, and be there while it's being done.<br /><br />Just a thought.
harrisg
Thanks for your replies, which gives me something to think about. However, I'm trying to get info from anyone who has used the products Vertglas or Poliglow.
PuddleJumper
I used vertglas on my 90 Astro. Worked as advertised BUT the step of removing oxidation did require some elbow grease. NOT completely effortless but I'm pleased with the results. Once done, adding a few coats yearly is pretty effortless.
fishingdan
I used Poliglow to clean up an older 20' yellow runabout. It also works as advertised. Easy to do and good results. De-waxing required the most elbow grease, but that wasn't bad since it was simply wiping with rags and solvent. Appling the poliglow is easy, but does require multiple applications (at least 4 coats). I too have a bad back, but have not had any surgery yet. The hardest part was trying to do it without bending to reach under the hull.
