nola mike
- Apr 22, 2009
- 5,591
'03 25hp 2 stroke merc (no s/n handy, sorry). Cruising today at 3/4 throttle, no problems, and I hear a very loud "thunk" sound, and motor starts to rev. I immediately pulled off the throttle and went to neutral. Engine sounded fine. Shifted into fwd/neutral/fwd. No problems. Went slow for a bit, then opened it up and all seemed well. Got home, pulled drain plug, looked good, no metal. So, what happened? Sounded like the motor slipped out of gear, but that shouldn't happen if my gears are good, right? Anything I should check? No slipping after that one instance, manually turning the prop in gear turned the engine, doesn't seem spun. It sounded like a "about to self-disassemble" sound, which I didn't appreciate.
