VERY quick question on adding Sea-Foam to 25hp
jerdogg1
Hello everyone. New to this forum. I just bought a boat with an early 90's 25hp Mercury tiller. I had read on this forum about using Sea-Foam to clean the carbs, etc. The can gave directions for how much to use and said use more to clean things out, so I added about 3/4 of a can to 5 gallons of gas/oil mix. I have run the boat twice since doing this, and I'm getting a lot of smoke off the motor, it seems especially at low speeds.
Is this normal? I suspect it's just the motor cleaning itself out, but just wanted to check in with the experts.
Thanks.
MadProps
Re: VERY quick question on adding Sea-Foam to 25hp
this is normal its NOW burning off the accumulated carbon
next tank should run clean
jeff_smith_0423
Burning off all the napatha that is in your gas now, too. Should smoke like a housefire.
