VERY Stiff Throttle - Is cable a DIY
Greenporter
2005 90hp pl Johnson
I will go through the suggested test of disconnecting the cable at the engine to see where the problem is. I have a feeling the cable has a kink in it. If this is the case should I attempt to replace the cable myself?
Any pointers?
Thanks in advance.
tashasdaddy
Re: VERY Stiff Throttle - Is cable a DIY
not brain surgery, if mechanically inclined.
