jtexas
- Oct 13, 2003
- 8,646
This is about a marine deepcycle battery powering a 36# motorguide. The battery is about 10 months old, the T/M is a few years older (don't know exactly).<br /><br />I'm running out of power too early in the day, sooner than I used to. My habits haven't changed - I use it a lot on the highest setting.<br /><br />Here's the strange part: last two times out, when it started getting noticeably weaker I measured the battery voltage at 11.8 & 11.9 volts. When I got home couple hours later, it was at 12.5 & 12.7 volts. First time I thought I was just crazy or sloppy with measurement or something. Hydrometer shows all cells near the top of the scale.<br /><br />I've been very particular about always charging it at soon as I got home using 6-amps, and it hasn't needed water. After charging it typically shows a little over 13v. When I left the house Saturday it read 13.1.<br /><br />I recently replaced the plug, wiring and recepticle, using 10 ga. wiring. Tests show minimal resistance.<br /><br />Any idea what's up with this? I can get a free replacement batt, but I'm wondering if this is symptomatic of a T/M problem.<br /><br />thanks,<br />jtw
