VHF and DSC on inland lakes
Redrig
Master Chief Petty Officer
Hello all ,
I have got my boat all remodeled and am soon to be doing alot of boating with my 8 year old boys In the summers .
The worrier in me always like to prepare for the worst . I currently don't have a radio in my boat and that will be a must when kids are involved .
so I will be installing a VHF radio soon.
​ I have been doing a little reading and have read about DSC and that sounds like an awesome feature , but we will never be boating anywhere near the coast , we live in Utah . so the question is dsc even useful Inland ? If I get into some jackpot situation and hit the red button does that even do anything in lake Powell for example ?
Thanks for the help
remember, some places on Lake Powell it will take a rescuer up to 30 minutes to get there. DSC couldn't hurt.
Also, is VHF even good in some of those canyons? radio does work by line of site.
Redrig
Yeah , I guess thats my main question with the whole line of sight thing .
I have heard stories about Powell where to get help , it involved several boats relaying messages from the main channel to the park service .
in the side canyons I beleive they are indeed worthless even if you had a 100 ft antenna, but the main channel where its a little more open and you can see some of the mountains I believe you can get decent reception. (same with cell)
On a side note , does anyone know if a hummingbird 597 ci hd di with GPS can link up with a DSC radio ? I cant find anything in the humminbird manual .
StingrayMike
If there are any boats within range of VHF with a radio, then they would be able to help you, so 2x what Scott said.
also
Looks like that unit can output nmea 0183. So it could send GPS info to a VHF aslong as if it accepts 0183. Here si what I found:
The back panel of the display has connectors for the XNT 9 DI T transducer, a power cable, and a for an optional cable that will let the 597ci interface with other NMEA 0183 devices. All the cables run through the inside of the mounting bracket making for a clean looking installation.
not sure of your radio manufacturer, if icom, try this:
The correct way to wire this is as follows;
HB NMEA Output + (white) connects to Icom In + (Inner conductor of the Red NMEA Input
coaxial cable
HB Ground – (black) connects to Icom In – (Outer conductor of the Red NMEA Input
coaxial cable
Important – Do not connect the HB
Red 12
VDC wire, cap and insulate this wire, its 12 VDC and will damage any NMEA port it gets connected to.
If other than Icom, just need to look at the manual for the radio and it will tell you what the NMEA input wires are
GOOD LUCK
Redrig
Dang great stuff stingraymike , super helpful !
I don't have a radio yet so I will be shopping for one of those .
StingrayMike
No Problem.
its easier to do searches for information when you know some of the lingo.
Just do a search for that interface cable before you buy...
also
you can get VHF's that have built in GPS for DSC function as well
mike_i
Ensign
I'm a saltwater guy and know nothing about boating on a lake. I would say a radio can't hurt, at least it's one way to communicate in an emergency if nothing else than to another boater. If radio communications is useless on the lake you can also get a PLB for emergency. Can you ask the park service what frequency they monitor and ask them about coverage on the lake and see what they recommend.
satellite radio helps in lake powell. Cell only works if you have line of site on Navajo mountain
Always publish a float plan
Redrig
dang those PLBs are slick , I have never seen those before , thanks for the tip. That is what I was hoping a DSC would do when connected to a GPS .
Redrig
yup , that is what I hear about the south end of the lake . I spend most of my time on the north end where cell reception is even worse . The only place I have ever got a bar on my cell away from a marina is at the Rincon
The only place I ever got cell reception was at the Dam Bar..... LOL
Redrig
I just scored a nice new cobra fixed mount with GPS built in . Now I just need to get an mmsi and antenna and hook it up .
Any antenna recommendations for an 18 foot boat ? Is an 8 footer overkill ? Are those little stainless canister ones sufficient ?
dingbat
The size of the boat is irrelevant in an antenna discussion. It comes down to performance. How far do you need to transmit?
VHF is basically line of sight. You can see a lot further standing on a chair than sitting on the floor. Same holds true an antenna
Assuming both antenna are mounted at the same level on the boat, the 8 ft. antenna will have a radio horizon of 4 miles compared to only 2 miles for a 3 ft. antenna. You add the two radio horizons of both antennas (broadcast and receiver) together for an expected transmission distance. In the 8 and 3 scenic your transmission distance is 6 miles. Make them both 8ft. and distance increases to 8 miles.
I
however line of sight on lake powell is only about a mile prior to the canyon walls turning. so a 6' would be sufficient
if you plan on boating elsewhere, then go with the biggest antenna you can.
Redrig
thanks for the tips , I will get a big one that can lay down when not in use
dingbat
Choose wisely.
The difference in the quality of construction from one model to the next can be substantual.
mike_i
Ensign
Size isn't the only factor to be concerned with. 8db gain is your friend.
