Re: VHF antenna
With the exception of certain strange atmospheric phenomena, VHF primarily works by line of sight.. <br /><br />For the best range, theoreticaly, you want to use the tallest antenna you can get away with, and mount the antenna as high as possible.. <br /><br />8' fiberglass Shakespeare Centennial has 6bd of gain, and thats about the best "bang for the buck" that you'll find.. Prices generally run $40 to $50, and add $30 or so for a good stainless steel ratchet mount...<br /><br />The 3' stainless whip antennas (like a car am/fm antenna) usually only offer 3db of gain, but that might be all the antenna you need depending on how far you venture out... Usually around $40 to $50 bucks, plus a mount.. <br /><br />Also... Don't mount the antenna too close to the radio... At minimum of 4 to 5 feet between the radio and business end of antenna should be fine..
