Some folks here might be interested in this
  I just got off the phone with the EM people at Underwriters Laboratory about VHF radiation and its (controversial) effects on human tissue.  What occurs is the VHF transmission frequency is an ideal wavelength to penetrate and vibrate cells in the human body.  The vibration action heats the cells such that we are slowly cooking ourselves.  No one knows the long-term affect of this VHF bar-b-que so the FCC has established guidelines to limit the cumulative exposure.  When a product does not test within FCC regulations, the manufacturer puts the responsibility for compliance on the installation, where corrections for the products shortcomings have to be made.  (Note: VHF radiates through the antenna so how the receiver could ever be made to comply is beyond me.)<br /><br />I ran into this issue while pre-reading the manuals of VHF radios prior to purchasing a radio.  I decided on an ICOM IC-M602 with a Shakespeare 6db gain antenna.  ICOM mentions that a 9db gain antenna needs to be at least 5-ft away from everyone at all times or metal shielding in place to protect people from VHF radiation.  We cant get 5-ft away, about 2-ft at most, so we need to install the shielding.  Obviously, we arent shielding the antenna, or it would be an antenna anymore.
   The directionality of the antenna could become an issue if the transmission beam is focused at people.  Our antenna will be located overhead, vertically so this shouldnt be a concern.  It was suggested a grounded foil or even metal mesh as large and simple as chicken wire, installed across the top of the cabin is all that is needed.  We will install a metal mesh before reinstalling the cabin headliner.<br /><br />1w, 3w, and 5w, handheld VHF radios are worth rethinking if this issue is important to you.  They are powerful enough and they radiate right into your head, but to an unknown total affect.  It is a similar issue to the cell phone controversy.  That was mentioned also, and yes, from what I was just told cell phones are a source of brain cell damage, but again, the long-term affect is not known.  Maybe it doesnt matter.  Could go either way.  (Does this imply I have extra brain cells?  And can I wire them for immediate use?
  )  The person I spoke with seemed to think a lot of the cell phone controversy is motivated more by politics than actual science.  There is also some controversy with the VHF as well.  The person at UL looked up the references for the actual frequencies and suggested it may not be a bad idea to go ahead protecting against them.<br /><br />Has anyone on this forum done anything to address this with your VHF radio/antenna?
