VHF Radio
ldl46
is anyone using a Midland Regatta 2 radio with a GPS connected to it and if so what GPS are you using? (Midland was NO help)
tommays
Re: VHF Radio
I read your manual online and it has a PS2 connector for the GPS which is something i have never seen before ?
BUT did they give you the other hafe of that PS2 plug ? You will need one and it should break out into 3 wires
1.single ground
2. input from the GPS
3.output to the GPS
There all the same it is just a matter of finding the wire color they use
the manual is useless :( you would think someone at Midland could ID the wire colors
Tommays
ldl46
Re: VHF Radio
the people at Midland was useless. there are two wires coming out of the
PS2 plug and are labeled + & -
bruceb58
Re: VHF Radio
According to the Midland manual it states the following:
GREEN: to GPS +
YELLOW: to GPS -
These two wires will hook up to your GPS NEMA outputs.
Not all VHF radios output to the GPS and it looks like this one doesn't have that feature.
Does this help you?
