VHF Wires
jpmurphy
The VHF Radio I just bought has a male/female pin plug on either wire. Do I need to keep these plugs or can I simply cut them off and wire straight to the main fuse bar/box ?
I'm thinking I can but want to make certain before I start cutting.
many thanx..:)
dingbat
Re: VHF Wires
You can certainly cut them off, but then how are you going to remove the unit from the boat without unwiring it each time?
jpmurphy
Re: VHF Wires
Gee. Good point ! :redface::redface::redface:
Silvertip
Re: VHF Wires
The fuse panel has either screw terminals or spade terminal connections. You disconnect them the same way you connected them. Plugs are not necessary and actually invite corrosion.
