Vibration at low speed
Smokey988
I have had a vibration on the new style Alpha one Gen 2 since I purchased it used a few years back. U-Joints and gimbal bearing are new.
The vibration only appears in the water between 5-10MPH but is annoying. Above that speed no vibration is felt. I checked the propeller shaft and it looks to have between 5-7 thou of deflection.
Over the years I have had 3 or 4 propellers and all are exactly the same. At the speed when the vibration occurs I swear I can feel it in the steering wheel.
Am I looking at coupler or the propeller shaft as the culprit? My thought is the coupler would vibrate even when not in gear at that certain rpm.
j cat
did you grease the u joints every year in the fall to set it up in the winter ?
inspect the lower unit ..inspect the lower unit top cap to see if water had oil in the out drive ..
do you pull the drive every year, inspect the gimbal, u-joints and alignment?
achris
More fish than mountain goat
Need to know what engine (model, year, serial number). Some engines have an inherent vibration in the 1700-2200 rpm range... (which is exactly the sort of speed you're referring to)
Chris.........
Smokey988
yes. I pull driver every year and use alignment bar. Last year I pulled drive and replaced gimbal bearing and u-joints. All last summer same thing with the annoying vibration at slow speed coming in and out of no wake zone.
Last fall took drive off again, replaced u-joints again, gimbal bearing, u-joint shaft, yokes, new bearings and set the rolling torque correctly with dial indicator torque wrench.
The alignment bar goes in and out with one finger and grease marks look good.
Took boat out on the water last week and same low speed vibration.
Back to the drawing board. When I measure the tolerance on the prop shaft I have about .13mm which works out to 5.11811 thou. Manual says over 7 thou is considered bent.
I figured for sure it was going to be the upper bearings in the drive housing as they were not smooth when I pulled them out.
Smokey988
Chris.........
Hey Chris,
First let me thank you for all the videos and information you have posted over the years. It has certainly helped me a ton. So Thank You :)
The motor is a 2007 4.3MPI 220HP serial # 0W670363.
Scott06
I know you said you tried several props, but were any of them balanced? I had a similar issue had the prop balanced at a repair shop and issue went away. Was fine at high speed but I must have bent it at some point kissing bottom
Smokey988
Originally it came with the mercury prop and a Apollo stainless prop, and I now have 2 new aluminun props. All are exactly the same result so I am thinking not propeller.
achris
Yep (I suspected). As you see by my signature I have the same engine. Mine does a similar thing at the same engine speed, as did my 1994 4.3LX. They are a 90 degree V6, and that's an inherently unbalanced configuration, and it's most noticeable under load, almost gone completely when not under load. GM even put a Balance Shaft in to try to alleviate the problem, but it's still there. Next time you're out lift the engine cover and watch the engine. It'll be going up and down slightly at that speed. That's your vibration.... There is no cure....
Chris...
kenny nunez
I had a few OMC customers with the early version that did not have the balance shaft. It felt like the engine was having a misfire.
Smokey988
Chris...
Thanks Chris.
nola mike
Chris...
Interesting. Noticed the same thing on mine as well, didn't think it would be an issue with the balance shaft.
achris
It's not an issue with the balance shaft, it's why the balance shaft is there. On the engines before the balance shaft, Merc used fluid mounts to try to reduce the vibration..
Chris...
nola mike
Chris...
Well, I'm just going to assume that's how it is 😃
I've been chasing u-joints, gimbals, couplers since I installed the engine (though since all checked out I gave up. 500 rpm of slight vibration still better than the 4600 rpm of vibration with the old setup.
QBhoy
Hey Chris,
Don’t suppose the balancer shaft and wheel is loose ?
Rick Stephens
Chris...
So even with a balance shaft the motor wriggles around? Yuck.
(My morphodite 4.3 has no balance shaft)
What happens if you add fluid mounts to that setup?
QBhoy
Any pics of the prop ? Presumably the thrust washer is in place ? What prop you have on her ?
What rpm is she at when this happens
QBhoy
It could be other things too. More thinking around engine causing it. Bad fuel, water getting in from frost damage or the famous diz cap failing.
