vibration from 8 hp mariner sn no 9509098.
roxylass
have looked at all the threads but cant locate the year of this model.
problem is just recently starting to get a very bad vibration from it, cant give it full revs because holding the tiller is sore on my arm.
all help more than wellcome.
kind regards.
carholme
Re: vibration from 8 hp mariner sn no 9509098.
roxylass;
Engine comes up as:
8 09503670 - 09546639 1988
from here:
http://www.marinshopen.se/Motorer/O...nsårslista/Mariner28hp/tabid/458/Default.aspx
Parts listing here:
http://www.crowleymarine.com/mercury-outboard/496.cfm
Very little information to start troubleshooting but you have to start with the basics. Any loose or damaged rotating components, mounts, damaged/loose prop, oil level/condition of oil in lower unit. lower unit or middle section not secured or loose, etc., etc., etc.
Have you removed the LU to check for oil and freedom of rotation?
Gerry
