I have a 1979 Renken with a 140 mercruiser. I have a bad vibration that shakes the whole boat. The vibration is with and without the outdrive on the boat. So it doesn't seem related to alignment in any way. I also changed out the engine coupler because it seemed warped (I would align the motor and then turn it over and the alignment would be off). The motor seems to run fine and I have checked the compression on all cylinders. It is likely that this is more of a boat issue than a motor issue?
