I decided to post a new thread on my motor woes, since the water pump issue has been resolved. My current issue is that I don't think the motor is "revving" like it should. According to the designer, a 25HP motor is more than enough motor for my Macomber 15 skiff.
I figure if 25HP is enough, then 35HP ought to be able to plane her out. So far, I've been wrong. We took her out for the first time last weekend, and due to a host of motor issues we weren't ever able to get her to plane. I'd guess top speed at WOT was about 10-12MPH. At WOT the motor sounds like it's ventilating/cavitating, but I don't know for sure. Here's a short video clip of the motor running at idle and at WOT (does not make the vent/cav sound in the barrel):
The designer did not specify - and, incredibly, I didn't think to verify - whether a long- or short-shaft motor was necessary. My motor is a short-shaft; the transom is 18" high. The anti-ventilation plate above the prop is just a hair (~1/4") higher than the bottom of the boat. There's a 1"-thick outer keel mounted (obviously) outside the bottom, making the plate ~1-1/4" above clean water. Reckon I ought to cut the transom notch a little deeper, or should I exhaust all other possibilities first?
Thoughts?
Thoughts?
