Re: video of water spitting on 70's 85 hp
if we email our answers to you, the next guy with the same question won't be able to find it.
Those two holes beneath the powerhead on the aft side of the engine are "exhaust relief ports". When the lower unit is submerged, backpressure on the underwater exhaust makes starting and idling difficult; those ports are there to ease the pressure. Running on the muffs, no pressure in the exhaust tube, you might not ever see water coming out there. Or it might spit a little like in Michelle's video.
The 85hp evinrudes built in '78, '79 and '80 have an overboard indicator (aka telltale or pee stream), a water outlet on the lower starboard cowl, that shoots out a stream of water to let you know the water pump is pumping. If it's an earlier model it doesn't have one, which might be fooling your friend.
Other hand, if it does have a telltale and water isn't shooting out of it at all times when the motor's running, then somethings gone horribly wrong.
