MI Boater 65
- May 2, 2015
- 11
I'm getting my vintage '57 Cadillac Catalina prepped for the water (14' aluminum 3 bench seat fishing boat). I am finishing up the transom as I have had to replace the plywood on the inside and outside. I will be getting a hairline crack welded up next week on the hull v-plate and have a few missing rivets to replace.
I just finished mechanically going through the '59 10hp Evinrude and is running good after sitting since 1992 (points, coils, plugs, float, carb. overhaul, replace gaskets in lower unit, replace rotted pull rope and fixed the gas tank connection to motor).
The question I have is the boat has a pea green coating on the majority of the inside of the boat. It covers the whole floor and goes up the sides above the water line. Would anyone have an idea what this is? I'm assuming it is some kind of sealer for the seams and rivets..
Also, I saw there is a Gluvit product that would act as a sealer, would this be a good product to use? Any tips on prepping prior to applying?
There are some larger seams that will need some type of sealing. Any recommendations?
